MF35 Diesel Deluxe wiring diagram
mf35
New User
Currently I"m restoring a 62 MF35 with a Perkins diesel. It had caught fire and all the wiring was destroyed. I need a complete wiring diagram for this tractor including lights and gauges. Thanks.
Here is a wiring diagram for a MF 50 Diesel. It should work for you.
Paul, thanks for the diagram. It answered most of the questions I had but opened up some new ones. When I got the tractor it was setup with a + ground. Most of the diagrams I"ve seen have + ground. If I understand DC current this shouldn"t be a problem as long as the gen polarity is excited. Is this correct? My gen has two connections one marked F and the other A. I"m assuming the F goes to the F on the regulator and the A connects to the G on the reg. My starter has two smaller connection also. R and S. Which of these connections are used. The diagram shows one going to the NS. Again thanks.
I forgot to reply to the question of where the generator wires go. Yes, F on generator goes to F on regulator and A on generator goes to G on regulator. I am unable to answer the question regarding the starter. Perhaps someone else can respond to that.
After studying the parts book I assume the S connection on the starter would be used, not really sure what the R connection is for. Maybe someone else can clarify this for me.
