MF 202 with MF200 loader hydraulic reservoir filter
RalphL
Does anyone out there know where I can get a hydraulic reservoir filter for this loader. The pump is one the front with the reservoir right next to it, The filter should be about 6" long and 4 1/2 or so inches wide. Thanks for any help.
P.S. The filter has a separate screen that goes around the outside of it.
my 200 has filter looks like ball of yarn, got new one at Agco dealer
p/n 1752177M1, came with new gasket for the lid
my hold-down spring was gone so I cut new one to fit from spring I bot at Aubuchon
my screen was all gunked up, manual says to clean it with kerosene, lots of junk dropped into the resevoir so I emptied it and cleaned it up good
getting the suction line back to spec might speed up your machine
AGCO has good parts diagram on their website, log in as guest down at bottom and you can find all sorts of stuff, think I had to download a small utilty to view the pics, not in .pdf format
