I have a Masey 1100 forgive me because i do not know a whole lot about this tractor.
What i do know is its a diesel, it is turbo'd. Which from what i've gathered is very rare. Lucky me.
I have a serious problem and hopefully someone can help.
First off my dad bought this tractor and he is convienently out of town.
It is my stack tractor. I pull a 1010 stackliner with it.
Recently it has started to act up. It would run but the rpm's would jump about 200 or so about every minute or so. I was using it today and it just sputtered and died. I cannot get it to start. It has fuel. Oil is good. Lifter pump works.
I have fuel at the settling bowl, lift pump, both filters, and going into the injection pump.
I have no idea how to test the injection pump but if a bleed it i do get diesel and some air out of it. It turns over just fine and will try to start with ether. But dies as soon as it runs out of ether. The filters are brand new. I tried bleeding and priming the whole fuel system. No help. \
This just happened several hours ago and i'm out of ideas. I have the service manual for it but the picture and diagram in no way resembles the fuel system on that tractor (because of the turbo maybe i dont know)
Any help will be greatly appriciated. I have about 2000 bales to stack and no tractor to stack them with. Any advice or ideas or hairbrained schemes are welcome. Like i said. I'm desperate.
Also. If it makes a difference it has belly tanks that near as i could tell is fed out of the crossover tube under the tractor. This looks like something someone added at some point because there is a fuel line that runs into the top of the tank but it is plugged.
