The hydraulics in my MF135 UK with multipower transmission is full of water. I am installing new shift boots and i'm going to drain the hydraulics. I was told to pull both drain plugs then fill her up with a few gallons of diesel and run her for a few minutes than drain her again, and check to see if most of the lovely white sludge is out. I'm going to definately replace the auxillary filter, but how do you change the filter thats on the hydraulic pump? I tried reading in the manual, but i must have some how missed that part. The closest thing i found was how to pull the hydraulic pump. Also since i have the multipower hydraulics is there more than one internal filter? Also what is a good way to test the multipower, i dont see any difference if the selector is in high or low.
