When lifting a round bail or anything of mass, it barely lifts the object, but is better at lifting when its cold outside and you really have to turn up the RPM to get it to lift anything. It also seems like it has a pulsation as its lifting. We've had our MF 165 diesel tractor for 6-7 years now and the problem has been getting progressively worse. Would that be a symptom of the pump failing or the pressure release valve opening at too low of a PSI.
The second question is this: The clutch never fully disengages. Possibilities and possible cures? The adjuster is extended to its longest travel and the clutch still will not disengage. As you might guess, this is a real issue when your stuck in a corner and cannot get it out of gear unless you shut the tractor off or bump the clutch (Often resulting in new fence being put up)
Any ideas or suggestions are GREATLY appreciated. Trying to keep this MF in action as long as possible
