I have an issue with my 3pt system, it only runs off of an auxillary valve. i'm under the impression that some sort of modification has been done but i'm no expert on this subject. i got the control quadrant out, trying to free up the lever. everything seems to be in order except the stand pipe that goes up to the aux valve looks like it has been joined to the other lever assembly, so the only way the 3pt works is with the quadrant set to constant pressure and the aux valve operates it. does anybody see anything out of the ordinary in the pictures? the stand pipe does not come out of the assembly, that little splice box is welded onto stand pipe
