I'm having trouble getting the valve apart as per the manual. Manual says to put a punch into "cross drilled hole through port B and turn valve rod end to unscrew from valve spool". I am doing that but it seems to be torqued on too hard. I'm worried about damaging the valve body or of breaking my punch off inside the valve body.
Does anybody know, if I take the oil seal off of the rod end of the valve would I be able to get in and remove the snap ring and then be able to disassemble the valve without separating the rod end from the valve spool?
Thanks,
JP.
P.S.: Oh ya, I forgot to say that the reason I want to take it apart is because the valve is leaking pretty good out of the non rod end. I'm hoping that there is something simple, like o rings, that I can fix in there.
JP.
Thanks,
JP.
JP.
