I have had a leak from the bottom of the injection pump for a while. I attempted to fix it today by removing the housing. After removal, I discovered that the housing has a fine hairline crack where one of the plugs that holds the spring mechanisim in place.
Does anyone have any idea of where I could get this housing. I am not sure which brand of pump that I have-the tag on the pump is not legible.
This housing sits on the very bottom of the pump, and has two plugs that hold a spring in place. There is a shaft with a ball end that comes out of the bottom of the pump, and this spring engages that shaft.
I hope I have described this well enough-my manual has no info at all about the pump. If need be I can take some pictures.
Thanks
Thanks
