Company Logo Shop Now
TractorLinks.com
Tractor Memorabilia Discussion Forum
Did they make a die cast of this particular tractor?
tazdale
11-07-2018 17:32:13
I have a friend that is looking for a die cast of this particular Case 970 Agri-King tractor. My friend has one that is this tractor but it has a dual wheel on one side for plowing. My friend wants one that was made with single wheels on both sides. I have searched all over the internet and can't find one. Has anyone ever made one like that? I don't want to waste more time looking if one was never made. I have attached a picture so you know what tractor I am looking for. Thanks for any information you can provide.
third party image
Adirondack case guy
11-16-2018 13:37:55
 Re: Did they make a die cast of this particular tractor? in reply to tazdale, 11-07-2018 17:32:13
There have been several versions made of the 9-1070 open station toy tractor since 1970. Ihis is a pic of the first Ertl 1070. Google CASE Toy Tractors and you will find several toy dealers on line.If you want to make an exact replica of his tractor, google Dakota Toys and you can order dual wheels and tires, plus 970 decals, and other accessories such as 3pt.
The last 2 pics are of a custom 930 toy which I built a proper front axle, cab, and swinging drawbar with 3pt., and the last pic is of real one that the toy was modeled after. I plan on building a replica plow for the toy this winter.
third party image
third party image
third party image
SVcummins
11-19-2018 18:30:24
 Re: Did they make a die cast of this particular tractor? in reply to Adirondack case guy, 11-16-2018 13:37:55
That is a neat tractor . Do you have the j bolts to hold the duals on ?
Adirondack case guy
11-22-2018 10:21:24
 Re: Did they make a die cast of this particular tractor? in reply to SVcummins, 11-19-2018 18:30:24
If you are referring to the 16th scale 930 The duals were a kit with J bolts from Dakota Toys. I custom built the cab from brass sheet stock, and the front axle was also constructed from brass tubing and RC car parts. The 3pt was a combination of scratch built parts and pieces from Dakota Toys.
Loren
SVcummins
11-24-2018 00:11:44
 Re: Did they make a die cast of this particular tractor? in reply to Adirondack case guy, 11-22-2018 10:21:24
You have a lot of skill building stuff thatís for sure. Iíd like to get a set of those duals to put on a 3020
tractorguy2
11-11-2018 10:00:49
Ertl made a 1070 open station about 1998? It is the same casting as the 970. Just change the decal and you have a 970.
tazdale
11-10-2018 01:53:11
I've seen this one, it has a dual wheel on the one side. My friend already has this particular one. Thank you though!!
d beatty
11-14-2018 18:10:21
 Re: Did they make a die cast of this particular tractor? in reply to tazdale, 11-10-2018 01:53:11
You could take dual off it's not that hard.
d beatty
11-09-2018 23:06:51
There is an open station 970 Case with plow by Ertl right now on Ebay
third party image
Adirondack case guy
11-16-2018 14:06:10
 Re: Did they make a die cast of this particular tractor? in reply to d beatty, 11-09-2018 23:06:51
Never mind the link. I found it. A bit pricy for me.
Loren
SVcummins
11-22-2018 16:36:10
 Re: Did they make a die cast of this particular tractor? in reply to Adirondack case guy, 11-16-2018 14:06:10
I should have bought that case with plow when it was still 60$ holy cow
Adirondack case guy
11-16-2018 13:48:54
Can you provide a link to that tractor and plow???
Loren
IaGary
11-10-2018 10:50:17
That 970 must have come out in the last few years. I knew nothing about it nor did my guide from a few years back.
d beatty
11-09-2018 23:05:32
IaGary
11-09-2018 06:46:27
There is a 970 with cab that came out 1998.
There is also a Black knight edition that came out in 2002.
No 970 without cab was produced that I know of.
There is a 1270 without cab that you maybe get a decal set made for and change the decals.
Adirondack case guy
11-16-2018 13:44:24
 Re: Did they make a die cast of this particular tractor? in reply to IaGary, 11-09-2018 06:46:27
The 1270 is a wide body toy. There are a number of narrow body versions out there that would make a better replica. I never saw that 970 with plow either. I may have to order that.
Loren
