Rds-40s
New User
Any one know how to pull them hubs off a 40s John Deere
This post was edited by Rds-40s on 12/26/2023 at 11:48 am.
Welcome to the forums.
One can guess you are referring to the rear hubs, but it is best if you clarify which hubs, you are asking about, front or rear.
A couple pictures of what you have might help as they may have used a couple different types of hubs.
Here is some info on posting pictures.
You cannot paste pictures directly from your device into posts here. To post pictures look down the page a bit from the box where you type a reply, and you will see a bar that says ''Upload Photos/Videos''. Below that is a button that says ''Choose Files''. Click on that button to go to your device where you can search the files in your device (computer, tablet, phone) to find the picture you want post, select your picture, then click the ''Open'' button and the program will upload that picture to your post. There is a size limit of about 7 MB of pictures/video per post (not per thread). That can be one picture or the total of several pictures in a post. This is the same in Modern and Classic views. Some cell phone pictures need to be reduced before they will post. And sometimes it takes a bit for them to upload, so don't hurry the process and use the preview button to see that the picture(s) is there before hitting submit.
You need to rig up a puller and when you get to about 30 tons apply some heat to the hub. It will sound like a shotgun when it lest loose.
I'm not sure what type you might be working with since images are not appearing.
This may be similar. It's a '36 B which had a hub securely fused to the axle. The tapered compression hub should be removed completely. The axle and wheel bore should be soaked liberally with penetrating oil
The hub area can then be heated, and lightly driving flat chisels as wedges (LIGHTLY!) into the expansion slots in the wheel hub can help. Apply pressure to the wheel with a suitable puller, and apply additional penetrating oil and heat as necessary.
This one was fused pretty solidly, but relented after less than an hour.
