oil should not ooz from there ??
olgentdc
11-20-2023 20:54:58
My 4020 has a leak that has transmission fluid oozing out of the flywheel timing cover , I think it is transmission fluid ,i keep loosing fluid somwhere , now it seems to had really gotten bad ,.. probably a front seal to Power Shift tranny. In what condition can i expect the clutch to be in ?? Since its Power Shift ,does it even have a clutch? I am in need of a reputable shop in the Louisville Ky 100 mile radius to split this 4020. and do the necessary repairs ,. Any advice You guys could help me with is appreciated , JIM
wore out
11-21-2023 09:03:44
 Re: oil should not ooz from there ?? in reply to olgentdc, 11-20-2023 20:54:58
ABSOLUTELY, Jim! LOTS of seals/seal rings involved and no better time to replace them than while the multiple clutch unit is already apart.
I find it STRANGE how small and ''thin'' that front pump seal is, it seems it wouldn't allow for any wear, play, or slight misalignment.
I've replaced them while in the PS for something else, but don't recall dealing with one that was leaking, though.
Tx Jim
11-21-2023 08:36:53
Thanks for correcting my mistake but in reality I think if tractor is split all seals pertaining to clutch pack should be replaced
wore out
11-21-2023 08:15:23
[quote="Tx Jim"]
FWIW,
Front pump/transmission input seal is Key # 15 at the link below, Link, part # R34650.
R33246 is a clutch operating piston seal.
tim s
11-21-2023 05:31:58
To add to the seal issue ,, a lot of times the front pump wears to where it will push more oil forward than the front seal can deal with,,so be sure to check it for wear,,and I would be glad to repair it,, but I'm a bit out of the 100 mile range.. But I do have a 4020 here from eastern Tennessee for an engine O/H
olgentdc
11-21-2023 06:45:43
 Re: oil should not ooz from there ?? in reply to tim s, 11-21-2023 05:31:58
tim s , Hello , Your county is a lot like mine Harrison IND..I am about as far as Kingsport TN , for distance traveled, I really don't want a haul that far ,,. Thank You for Your response and advice . Hopefully , I will find someone local and loyal to Case having a c-! clutch pack changed out by one of the Whiz kids. I want to get everthing fixed now that i have retired.
tomstractorsandtoys
11-21-2023 04:55:35
Haul it to Sommerset OH to TimS. He does great work and has plenty of experience. Tom
Tx Jim
11-21-2023 02:09:33
4020 with Powershift trans has a dry damper clutch. One might be able to remove clutch while tractor has been split & clean/heat clutch plate to remove oil. I agree with Dieseltech that Powershift clutch assembly must be disassembled to replace seal part # R33246(item 10). Link
Dieseltech
11-21-2023 01:28:02
My 4020 Powershift front seal was cracked in two places and leaking badly. The complete C1, C2, and PTO clutch pack has to come out and torn down to get to the pump/front cover area where the seal is.
