john deere 1530 diesel
steve duplechin
11-20-2023 06:02:15
Is there a way to manually prime the injector pump? I get fuel to the pump, but through it to the injectors.
Dieseltech
11-21-2023 01:24:35
 Re: john deere 1530 diesel in reply to steve duplechin, 11-20-2023 06:02:15
When did engine last run? Injection pump MIGHT have stuck internal parts from setting if there's ANY traces of water in fuel, or Bio diesel fuel in system. I've been seeing that a lot on pumps in for repair lately.
used red MN
11-20-2023 19:36:27
Has the tractor been setting 6 months or more? If so it is likely there are parts stuck in the injection pump not allowing it to pump. Needs to be taken off and rebuilt.
Dieseltech
11-20-2023 08:05:00
It's the injection pump's job to supply fuel to injectors, the feed/supply pump only supplies filters and injection pump.
buickanddeere
11-20-2023 07:45:29
Ran it out of fuel ? Using the primer or cranking ?
How do you know fuel is at the pump ?
buickanddeere
11-20-2023 07:38:53
steve duplechin
11-20-2023 10:34:14
 Re: john deere 1530 diesel in reply to buickanddeere, 11-20-2023 07:38:53
we cracked the line to the injector pump and got fuel there by turning the engine over. No fuel goes out the pump to the injector. Is there a way to prime the pump?
centash
11-20-2023 16:46:22
 Re: john deere 1530 diesel in reply to steve duplechin, 11-20-2023 10:34:14
Should be a small bolt like fitting on the side of the pump. Take it out and crank engine until the stream of fuel coming out has no air in it, just a steady full stream of diesel. When it does, simply turn it back in to its original position. Cranking should now bleed the injectors enough for the engine to fire.
Ben
