John Deere H running bad high carbon
Jim Nauert
11-18-2023 12:27:46
My John Deere H is running poorly, keeps getting high amounts of carbon on spark plugs. I have had the carb professionally rebuilt, new wires new condenser in mag, changed plugs multiple times and checked the timing multiple times. What else could it be?
Jim Nauert
11-20-2023 12:09:29
 Re: John Deere H running bad high carbon in reply to Jim Nauert, 11-18-2023 12:27:46
Running quite a bit better, put in some non resistor plugs and discovered one of the tappers was set too tight.
Mark-Ia
11-19-2023 09:03:29
Turn the Load screw in on the carb. Black smoke is too much fuel. Just because it was rebuilt, doesn't mean the rebuilder set the carb to run correctly.
westga
11-18-2023 17:41:08
I would check the intake air from end to end.
From where it enter to the carb. This will be the cheapest thing to do next. You can make sure the oil levels right in the breather also.
rustred
11-18-2023 17:01:04
what else can it be?... a worn out engine. oil fouled. check the compression. are u monitoring if it uses oil?
Richard G.
11-18-2023 12:34:37
Make sure the air cleaner is not clogged up to start off.
JIM MN
11-18-2023 12:58:18
 Re: John Deere H running bad high carbon in reply to Richard G., 11-18-2023 12:34:37
Get coolant temperture up to 200 degrees.....
Jim Nauert
11-18-2023 13:15:23
 Re: John Deere H running bad high carbon in reply to JIM MN, 11-18-2023 12:58:18
I was discing with it so had the temp up, almost didnt make it home because no power.
Loosehandle
11-19-2023 05:29:49
 Re: John Deere H running bad high carbon in reply to Jim Nauert, 11-18-2023 13:15:23
Sounds like its running on one cylinder sometimes, double check point gap and strength of spark when warm.
JIM MN
11-18-2023 15:15:36
Other thoughts; does the tractor burn a lot of oil? And what gas are you using? Ethanol or not? Had the tractor been running OK before all this, now has lost power?
Jim Nauert
11-18-2023 17:05:36
 Re: John Deere H running bad high carbon in reply to JIM MN, 11-18-2023 15:15:36
It was running so so but was giving off a ton of carbon, doesnt burn any oil.
JIM MN
11-18-2023 19:29:13
 Re: John Deere H running bad high carbon in reply to Jim Nauert, 11-18-2023 17:05:36
Must be gas soot foul, does not use oil.. Use 87 octane gas.. Lean out carburetor,too rich.. Spark-plugs- try Auto-Lite 3116 non resistor with your magneto, they are the best or champion D21 or D23. Set plugs at .030.. Spark plug wires, copper centers.. Does magneto put out a hot blue spark.. And once again, when working tractor get coolant temp to 200 degrees plus.. Give these a try..
Jim Nauert
11-19-2023 04:26:34
 Re: John Deere H running bad high carbon in reply to JIM MN, 11-18-2023 19:29:13
Thanks, Ill try those plugs. Right now using 386 and those I thought were non resistor but discovered they are a resistor plug. Hopefully its a simple fix
