bruceharle
New User
I have a 1966 4020 gas with 12 V Pos. ground, single battery. I believe fuel gauge is bad. There are 2 connections on the gauge.
I confirmed the one connection is power and it has power (test light lights when I ground it). I shined up the connection on the gauge and it fits tight so I believe it is getting power.
I was expecting when I grounded the other post (sending unit connection - orange wire) that it would peg the fuel gauge, but it moves only about 1/8" up on the gauge (same as it does with sending unit) when I turn on key. I was grounding direct to the pos gnd of the battery when doing so.
Is this a valid test?
The sending unit has one wire and when it is connected to the gauge and I turn the key on, it moves the needle up by only 1/8" or so and the tank is almost full.
thanks in advance
bruce harle
De Soto, WI
This post was edited by bruceharle on 05/30/2023 at 07:43 pm.
thanks in advance
bruce harle
De Soto, WI
