Dan Nickels
Got a puzzler on my 2030 diesel...rear tire was seeping calcium from valve. I always keep some valve core housings in stock, so no problem swapping one out (I thought)..Jacked tire up, moved valve to top, and removed core housing. Usually lose a little air swapping housings, then re-inflate and problem solved. This time, lost no air...didn't give it much thought so put in new housing then checked tire pressure...none !!! Pumped in a bunch if air, rechecked and still nothing..did it twice more ( I could hear air going into tire), still nothing!?!? By now,I knew something was not right as tire was hard as a rock and I had no idea what pressure might be. (Tried two different gauges, also tried them both on front tire to make sure gauge was not at fault) Then I removed new core housing and gently poked a small dowel into valve. Felt like I was pushing on the side on an inflated tube !?!? Something was acting like a check valve of sorts letting air in but not out.?.? Tire is hard as a rock with core housing removed.?.? No idea what pressure in tire is, and no way to let excess out...Anybody ever experience this? I never have in my 76 years...I need help. Thank you...Dan
