4230 jumps out of gear
wlh
New User
I have a 4230 quad range and read in this forum that a spring goes from bottom of cab down to the pin in the shifter arm, Did these tractors have this spring when they left the factory? Is the spring part #R56776. And could somebody draw me a picture or photo where exactly this spring goes, I see no spring on my tractor now.
Upper part of spring attaches to cab frame & lower part of spring attaches to a hole in the connecting pin(item 10) of shifter rod.
This post was edited by Tx Jim on 05/26/2023 at 05:29 am.
Mine is a 75 SN 021205 The shifter rod #12 on mine makes a 90 degrees at the bottom and goes to the arm #8 there is no yoke #7 or threads on bottom of the rod, Do I still use the spring?
