Model A manifold studs
Tstoner
I am in search of some manifold studs. The only one I can't find for my 44 is A2386R. John deere says it is now obsolete. Does anyone know where I can find an aftermarket stud? I thought about making my own but since these thread into the water jacket I don't want them to leak
Although not correct I put them back together with bolts rather than studs. If you ever need to get it back off, you don't have to pull the head or
fanshaft/governor in order to do it. To your point just make sure your bolts aren't too long so they don't hit the push rod tubes.
I have put bolts in on several tractors. That way if ever needed I can remove it without pulling the
head. Just watch the length and put sealer on the threads of the ones that go into the water jacket.
(quoted from post at 07:32:15 05/23/23) I am in search of some manifold studs. The only one I can't find for my 44 is A2386R. John deere says it is now obsolete. Does anyone know where I can find an aftermarket stud? I thought about making my own but since these thread into the water jacket I don't want them to leak
I used bolts on my B. Applied Permatex Ultra Copper to the threads and antisieze to the non threaded part of the bolts. Hasn't leaked yet
*I made studs for my H using stainless steel bolts and nuts. Cut the studs to the right length and
chased the threads in a lathe. The threads I cut were for the end that goes into head. It's called an
interference fit. Just cut them so that a nut goes on fairly tight, not with your fingers. Use a
little thread locker on the bottom end
I need a set for my 51 A and my H. Going to try Martin. BTW, I think only the Bs had pushrod tubes. There's also Allen's Fasteners but I can't seem
to find any suitable ones there.
