John Deere 112 and 212 Belts
DJ15865
New User
Hello,
I have a 1968 John Deere 112 and a 1984 212. Both are used for mowing. I recently chewed up both of the mower drive belts from the pto to the deck. The local dealer is having trouble figuring out which belt for the 112. For the 212 they are saying belt M47765 which I think is correct.
112 info
Tractor T0650 110198M
Deck E0670 107239M
Any one know which belts I truly need?
What model is the mower deck on the 112?? If you don't know for sure what it is I can do some digging based on the type code and serial number.
Another thought is look at the belt and see if you can read a part number anywhere. Unfortunately that's easier said than done because they usually get chewed up right where the part number is. Pretty sure they're designed to do that :roll:
The deck is a model 47. I tried to find the number from the belt but it's wore completely off.
After some more searching I think it takes belt M45998 but not 100% sure.
M45998 is the one I come up with as well. Parts shows a serial number break at 205468. Since yours is the earlier deck M45998 should be correct.
