I was discing yesterday and all of a sudden i lost steering and remote hydraulics. i looked around the tractor if i saw oil leaks, when none found I unhooked the disc and tried to limp home. 500 feet down the field hydr transmission oil started shooting out under pressure between dr side tank and clutch housing that drained the oil reservoir rather fast.
Among a lot of other things i had installed a new clutch and transfer/charge pump drive gear and shaft and changed all filters and the trans fluid. tractor had not been used for a couple years before yesterday.
Tractor ran for 6 hrs with no issues till it lost the steering.
My repair manual does not seem to provide trouble shooting.
any pointers would be appreciated.
