I have a late model A where the wheels are right at the max on each axle and have been like that for 30 or more years. I have jacked it up and tried everything to get them to move, soaking with PB blaster for days, using heat, putting chains attached to the axle housing and throgh the wheel, and spinning the wheel tight, and I have had no luck. Any suggestion would be appreciated.
I am thinking about using two threaded rods through each side of the hub and then attach them to the axle housing. Then trying to use a impact wrich to tighten nuts on the hub oping that will break the hub free and move it a little. What do you think ?
