Oil pump set screw for 320
(quoted from post at 06:56:04 05/22/23) thanks will check.
That screw has a fairly important job to do, securing the oil pump.
If you GOOGLE the part number it's not hard to find one, even a new one on ebay.
I'd either get a new or used one or measure the tip angle and make one on the lathe to be sure it entered and secured the oil pump ''stem'' as well as the original. (Matching angle and proper fit.)
