Deere 2020 rockshaft adjustment
W4114C3
New User
I've got a jd 2020 tractor and when the rockshaft selector is on L&D the 3pt works as it should. But when put to the depth setting the 3pt lifts about mid height with the 3pt height arm all the way down. I've read several posts about adjusting this issue on other models with a 9/16 socket welded to an extension but I am unable to find the location of where the access hole would be for this tractor to make this adjustment. Assuming that's what it needs. Thanks for any assistance.
Hole you need to locate to access adjustment nut is the hyd oil filler hole behind operators station.
Correct method for adjusting JD L/D mechanism is by following the ""several steps"" outlined in a JD 2020 tech manual.
(quoted from post at 06:35:08 05/21/23)
You're welcome
Nut was designed to be adjusted with L/D lever in "L" not "D".
Ok nevermind I get what your saying now. My L lever isn't working perfect either so I'll make my adjustment while set on L and see what happens
