320 oil pump
bobgrimes
Started working on a 56 jd 320. The nut part of this fell
off when I put wrench. Obviously it broke off. What can I
do to remove and where does it lead to. Manual shows an
adjustment for pressure.
I think that is a tapered set screw that holds the pump up in place. Try mig welding a nut to it so you can unscrew it. May take a couple of tries.
Yup. Tried an allen wrench but there is nothing left to
grab on to. Tried various extractors but again its not
deep enough to get ahold of anything. What would
happen if I drilled? Probably have to retap threads.
