JWinIndiana
My goodness this has turned into a job. I am sure these bolts haven't been removed for 30 years. Two nuts came off. Cut the others off. Tire is off of the rim, rim is now off of the cast center. Have 3 bolts still in the cast center. Have heated the cast to a point, didn't want to crack it. Cut the head off of one bolt, removed the clip, drilled through the bolt up to a 1/4" drill bit. Still can't get it out. For the past month every time I walk by this tractor I spray lubricant on these bolts. Any and all tips and tricks will be appreciated as this is the first of two wheels.
