Wartime john deere model A rim size
Tstoner
I have a 44 A with a spoke cutoff on the front. I need to re rim the one I have any idea what the correct rim or tire size is for a 44 A? Currently only have one wheel on the front with no tire. The rim is so bad I can't measure it. Also looking for another wartime spoke front to match if anyone has a lead on one I appreciate it.
I put 15x4's on my G from these guys. The original rims came from a 37 A. I cut the spokes down and welded the new rims in.
Hey Wheel
(quoted from post at 17:00:14 05/16/23) I put 15x4's on my G from these guys. The original rims came from a 37 A. I cut the spokes down and welded the new rims in.
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto154721.png>
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto154722.png>
Hey Wheel
I think part of your picture was cut off. What was the company you got the rims from? And what size tires did u put on the 4x15?
Scroll to the bottom of the wheel picture. It says Hey Wheel there. Click on it and it will go to their website. I think the tires were 15-5 maybe? I went to
the little rim for the weight savings for pulling.
A should be 5:50x 16 inch with possiblity 6:00x16 Work, B would have been
the 5:00x15 size. G would have been the 6:00 or 6:50 x16 size
(quoted from post at 22:08:46 05/16/23) A should be 5:50x 16 inch with possiblity 6:00x16 Work, B would have been
Thank you for the help guys
