Working on another diesel 3010. Used it to drill in some seed and the steering was fine. Went to move it after setting for a few days and the steering is acting up. First it would turn right fine and turning left there was no power steering then it changed to left had steering right doesn't. Throttling up while not moving doesn't help,but moving with it will start to steer more normal but not quite right. Do you think this is the steering valve going out or is there another valve I should be looking at? This tractor was pretty abused when I got it so just working through the issues as they come up. Thanks
