730 Diesel transfer pump removal
Scott 730
Location
EC MN
Why is the pump fighting me to remove it? I thought there is just a tang on the pump shaft that mates into a groove in the governor. Shouldn't the pump just pull straight out after the 2 mounting bolts are removed? I can rotate the pump housing, but it will not pull free.
Yes, you are correct; pump should just pull off with two bolts out.. There must be
a metal bur on the drive shaft tang or the governor groove.. Maybe a little pry on both
sides of the pump will pop it free??
Thanks. I got it with a bit of persuasion. Need to clean up the groove in the gov shaft so it's not such a tight fit.
