Determined
JD401
Was loading up a semi with bales yesterday when the hydraulics started feeling a little weak.
Had a few hours to kill before the next load so I figured being that I had a spare transmission filter on the shelf I would put in in while I had the time.
Dropped the canister and discovered the filter I had on hand was the wrong one.
No big deal, I rinsed the old filter out in some solvent, blew it out and put it back in.
Now the fun began.
Hydraulics for loader, steering, 3 point etc were working fine but no forward or reverse movement.
First thought was that something was buggered up in the relief valve.
Pulled it out and checked it over and all as well, installed it, filled system back up with no difference.
Next thought was the transmission pump must be weak and not able to prime itself.
Checked for pressure at the reverser test port and had nothing.
Hung a vacuum pump off the reverser test port and pumped on it until it drew a 1/4 cup of oil threw it.
Still no forward or reverse movement but it was starting to make the lug down noise when pushing and releasing the clutch pedal.
Shy of splitting it to check the transmission pump any suggestions?
I was thinking of hooking a line off one of the remotes to back feed fluid through the filter/pump/pick up tube to prime the system.
Anybody had any experience or success with a weak transmission pump?
Now the fun began.
