730 Diesel countershaft bearing cap removal
Scott 730
Location
EC MN
Been too long since I've been inside the reduction cover. Can't remember if the countershaft bearing cap will come off with the pto idler gear and reduction gear in place. Thanks!
NO; Take off everything to get to the first reduction-gear cover.. Pull cover, pull
off first reduction gear; pull power shaft idler gear. Countershaft end bearing housing,
held on with three bolt is right there. PTO drive gear is right below.
