Mike(NEOhio)
- Location
- Newbury, Ohio
OK, what's the trick for getting it on the casting? The old stack had been broken off and repaired, held on with three 5/16 bolts, but sitting high
and the steering shaft wore a hole in it. I got a new NOS stack but it seems too tight, like it need to be expanded a bit. I'm thinking I should
grind off the old weld bead and have it welded but I don't want to ruin it.
Old stack with hole.
