Air cleaner
CharlesG
The air cleaner cup mounting band on my M has different circumferences side to side. Which goes up? Also there is a small hole in the band that I assume is to make it easier to install past the mounting brackets. When I install using the hole the the large side is up and the cup is loose. What am I doing wrong. TIA
Charles
Perfect!!! Thank you M-MAN. I had to alter the clamp ever so slightly to get it past the bracket. (I think the bracket is slightly bent.)
