I need help.
My 420 JD's carb is leaking.....I took it off...the carb.....hoping I could See where...it Seems that the gas is just running through it...it had a lot of gas in it when I finally got it off.....
It had ran for just a few minutes and needed to be choked...BUT finally just died.....the carb was rebuilt and has very few hours on it...the tractor SITS a lot...I have just gone out and cranked it on occasion....
Could this be the float sticking?...do I need to take the carburetor APART to check out the float?....will I need new gaskets?..... how will I KNOW if the float is Stuck Or Sticking...
Thank you in advance for any help...
Dsmythe
Dsmythe
