JD 2240 cam shaft
Toomanylbcs
New User
The ole water in the oil trick Im working on an in-frame rebuild. A couple of rocker arms ends are worn and pitted. Id like to verify that the
rocker arm assembly is disassembled to by removing the steel shaft end plug? That plug looks like its pressed into place then the center is
staked similar to a freeze plug? Is that essentially correct?
Larry
Hello Larry welcome to YT! Yes, the manual shows a slide hammer type dent puller being used to remove them. Check your email.
This post was edited by used red MN on 05/01/2023 at 10:29 pm.
