Brass debris in hydraulic oil JD 4640
gunnargt95
New User
Drained the hydraulic oil from my 1978 John Deere 4640 PS and found alot of brown looking debris(brass?) where can it come from?
I have owned the tractor for four years, and i have drained the hyd oil a couple of times, and every time I fine brass in the hyd oil. This time i drained it from the hole where the screen is, and i think it was alittle bit more brass debris this time.
The 3 point jerks a little when being raised and the steering also jerks alittle, but other than that the tractor work fine.
I know both axles was removed and work was done many years ago.
The largest piece looks more like a thrust washer that brass in brake pads. Have you checked hyd oil suction screen lately? If not I suggest you perform that task.
(quoted from post at 05:40:36 05/01/23)
The largest piece looks more like a thrust washer that brass in brake pads. Have you checked hyd oil sjuction screen lately? If not I suggest you perform that task.
This looks also like shims.
