I have a 1969 1020 that had the injector pump fail. I lined up the two timing pins according to the tech manual before I pulled the CBC pump. The diesel shop that I use called me and said that they couldn t rebuild it. They said the only option was to convert it to a JDB pump. We ordered the kit with all the new lines and and the JDB pump with the adapter shaft.
I have put everything back together, and timed the JDB pump through the window, but the holes on the shaft of the new pump do not line up with the timing gear. I pulled the shaft out enough to rotate it 180 degrees and it still doesn t line up. I talked to the shop, and they said it doesn t make sense. The only thing I can think of is rotate my flywheel until the timing gear lines up with the pump shaft.
I m curious if anyone else has come across this problem and what they did to resolve it.
