4020 powershift problem
aawirth
New User
Hi, I have a 4020 power shift, was working fine, started to, growl, moved home, all gears still working, shut down, went to move it to shop, all I have working is 1st, 2nd, and low reverse, has a very faint applicatiom in 7th, no growl now and pulls in gears that work, any ideas? thanks Al
Heres some easy checks you can make
I took apart, looks like the c2 pack, theres an O ring on the end of centre shaft thats not there, but that don't explain the growl, the brakes, b1 to b4 have good clearance, I think the growl came from a planetary pile up in one of the breaks, if thats the case, will not be worth while to fix.
