730 gas power steering
scarl
Just got a 730 running that had sat for 15 years. When we got it started it steered all the way to the right by itself and stayed there. Was told that it worked fine years ago. Is something stuck in the valve or something that may have stuck from sitting?? Any advice would be greatly appreciated. Thanks
A good manual should tell you how to adjust it. Worst is getting the nose cover off. Be careful when y0u adjust it as the wheels can take off and go all the way in
the opposite direction.
Thanks for the input. I have a power steering manual on the way. Hopefully we can figure out what vale is stuck or out of adjustment. I have the nose cone off and there are no leaks so that is encouraging.
