Changing front ends on 60
If both tractors have convertible pedestals it's a fairly easy process. Just make sure both have the same number of attaching bolts.
If not it's a lot more involved.
It is easier to go from a wide front to a narrow then the other way or at least it was on one of my 70D. When I took the roll-o-matic off I tried to use the same bolts to attach the square wide front. They are longer and can do some damage to the bottom of the pedestal . The narrow front from the 620 will fit your 60.
