History: tractor ran perfect. Put in new radiator and power-steering pump guts, and related gaskets/etc. NEVER touched the carb. Had to remove several wiring connections, but THINK I have them back correctly. Removed/emptied gas tank. Problem: tractor fires up on first rotation, runs for 2-3 seconds, shuts off. I can choke it, or not: same problem. I cleaned out carb side drain plug, hole behind it, top strainer/plug, bowl drain, and fuel lines cleaned out. With carb-bowl off, open fuel-valve, gas runs out (all along the top). Push up on float, gas shuts off. Seems there is ample gas to draw on. Then I heard of the 12v/6v/key issue. I turned key on, and it reflects a steady 7-volts at the coil terminal. WHAT am I missing????
This post was edited by Farmer MM on 04/17/2023 at 04:47 pm.
