Anyone have any tips on how to torque the screws to 300 ft/lb on the steering gear arm?
Front end is removed and the motor turns when applying torque.
If I re-install the front end and tie rods and put it on the ground will there be enough weight to stop the motor from turning?
The axle housing interferes with getting a socket on all screws ... maybe I have to turn the steering gear arm to get at each screw then lower back to ground to torque?
Appreciate any info here.
Thanks.
Thanks.
