6330 Knocking on Start up
Hotflashjr
Location
Western MA
I am doing some spring tillage work for a friend with their 6330, 4x4 tractor. Sometimes on start up it sounds like it is knocking. Plenty of oil, no idiot lights on the dash. It goes away in about 5 minutes when it does it. Outside temp. does not seem to change if it does or does not do this. He uses JD 15-40 oil and it was changed before the start of this season along with the filter.
Anyone have any experience with this?
Thanks.
(quoted from post at 05:07:39 04/12/23) I am doing some spring tillage work for a friend with their 6330, 4x4 tractor. Sometimes on start up it sounds like it is knocking. Plenty of oil, no idiot lights on the dash. It goes away in about 5 minutes when it does it. Outside temp. does not seem to change if it does or does not do this. He uses JD 15-40 oil and it was changed before the start of this season along with the filter.
Thanks.
If it is a common rail, this maybe the rail pressure sensor reading too low, making the injectors over inject fuel. Happened to my neighbour's 7530.
