2010 wide front on a 2510
Will a wide front end off of a 2010 fit on a 2510? Can I put taller tires on the front so it isn't like a hotrod from the '70's and jacked up in the rear? Thanks in advance.
(quoted from post at 08:22:14 04/11/23) Will a wide front end off of a 2010 fit on a 2510? Can I put taller tires on the front so it isn't like a hotrod from the '70's and jacked up in the rear? Thanks in advance.
Nope. Completely different front end.
There isnt much that crosses to a 2510 although you can
actually put a lot of bigger engines in it easily a lot of the rest
of the tractor was a little weird built same time as 20 series.
