3/4 Inch Oil Resistant Line - Supplier Needed
mtb34
Anyone know of a place to get 3/4" oil hose for New Generation tractors besides John Deere? My local dealers have it on order and only sell it by the inch?
I didn't see it listed on YT either.
I see some stuff out there that looks like it might work but have been warned to make sure I get the right hose or it will fall apart on me.
Thanks.
pretty hard to tell what u want. oil hose that can be a hose from fuel line to 4 braid hyd hose. give a description and what its for.
The JD part number and just what it is on/for might help. It sounds like you are looking for a low pressure return type hose or maybe for an oil cooler? A full service hydraulic shop may have something. A Parker hose and fittings dealer likely has or can get some. I have used Parker Push Lok hose for some such applications.
Without your location it is pretty hard to say suggesting the name of a specific place I might know would help you out any. You can web search for a Parker dealer in your area.
Any hydrauilc shop will have 3/4'' 250 or 300 psi hydraulic return line/oil cooler line if the DEERE dealer is out of it.
The parts guys at a nearby CIH dealer know what I'm talking about and can measure it off and sell it to me when the green dealer is out of stock, as well, nothing ''magical'' about it.
Sorry for not posting JD part # of low pressure return hose ... it is TY22563.
Thanks for the suggestions on where to locate. I will start tracking it down and buy 5 feet or so to have backup supply.
That hose is nothing special as far as pressure rating or casing material. I have a couple feet of it and it looks like heater hose, but isn't. A substitute should be readily available many places as posted previously.
Caterpillar will have what you need if the rest dont. Wont
have to wait. They do hoses upon hoses a lot of their
transmission coolers on wheel loaders would have similar low
pressure yet oil resistant
