4020 WON'T TURN WITHOUT USING BRAKES
bv
I have a friend that has a 4020 power shift that when you turn the wheels the tractor wants to slide forward like the rear end is locked together but you can hit the brake and it turns without any problem, this tractor does not have the differential lock on it, what do you guys think?
(quoted from post at 11:35:49 03/30/23) I have a friend that has a 4020 power shift that when you turn the wheels the tractor wants to slide forward like the rear end is locked together but you can hit the brake and it turns without any problem, this tractor does not have the differential lock on it, what do you guys think?
If it TRULY doesn't have differential lock it would seem the differential has failed.
Better have a look at it before things take a sudden ''turn'' for the worse, IMHO.
