Jd wheel rims
37 chief
My JD 401 b uses a 6 lug wheel. Is there a vehicle wheel that uses the same bolt pattern? I just need a spare. Stan
I think many tractors and implements use that same rim. Goes clear back to the 2 cyl. era. You could try a 6 lug chevy half ton 4 x 4 rim it may be similar ? Not sure if center hole is as big or not ?
Whats your location. I have extra 6 bolt 16 front rim. Shipping very far would probably be expensive?? Cleddy
