4430 steering
It's possible steering motor piston seals located under fuel tank have failed. Is this tractor's serial # below or above ""027635"". Below that serial # has steering valve similar to JD 10 or 20 series RC tractors. After posted serial # has metering pump steering
If the tractor steers hard all the time, one way, even after you do a full stop to stop cycle with front wheels you most likely have the early steering valve and it need to bee resealed and adjusted. About an 8 hour job if you know what your doing. Adjustments are very sensitive. Close don't count they got to be correct. It will steer better than a new car when right. DW
