IAtractorKid
Side console 3020 diesel
Last fall while brush hogging, started leaking hydraulic fluid from the clutch housing (video in this group from October). Not my tractor so I was not able inspect at that time...figured likely cause was the PTO pistons even though they had just been done last spring (previous owner).
Finally got the tractor to work on tonight. Tractor was not "hot" and obviously I didn't use the pto, but appears the PTO pistons are dry...even after having them engaged with no load. There is more oil towards the front and around the clutch. This leads me to believe it's the seal between the shafts.
What do you guys think???
Where is the seal between the two shafts? That is accessed from the clutch housing correct?
#29 is further back and requires the split between clutch housing and transmission case correct? If replacing #29, should the bushing #30 also be replaced?
Thanks!!
This post was edited by IAtractorKid on 03/23/2023 at 07:23 am.
Thanks!!
