Dreaming Green IN
The alternator light on the dash of my tractor barely glows at all.
The tractor is a 1964 3020 Diesel with PowerShift. It has been converted to 12V with alternator.
When I disconnect the wire to the alternator lamp at the key switch and put 12 volts to the wire, the dash light glows brightly. When I check the "Gen" stud on the key switch with the switch on it shows 12 volts.
So, why would the light not glow bright with the 12 volts from the key switch as it does when powered by my PowerProbe? (Yes, I cleaned the connections with electronic cleaner spray. And jiggled the wire at the connector.)
Thanks in advance for any ideas.
