lowell8970
New User
I have a '65 4020 24V, positive ground,power shift tractor. I just purchased this tractor late last fall and put a new Brillman harness on it. I do not know if it was working before,but everything operates correctly except for the gen light. It appears to operate backwards. Key on,engine off, the light is out. Key on, engine idling,light is dim. As you speed up the engine the light gets brighter. The generator is charging and the more it charges, the brighter the light gets. The oil pressure light operates correctly. What gives? Our other 4020 was converted to 12V at least 35 years ago.Should have done that to this one but I wanted to keep it original.
