Oil filter case gasket
Mark Poss
Im looking for an oil filter case gasket for a model W power unit. The part number is D2364R. Deere says no longer available. Thought maybe an oring would work but not having any luck matching the old one. Its 5 diameter outside and maybe 1/8 thick. Anyone know of a source for a gasket? Thanks Mark
If you have access to a paper WIX Filters catalog IIRC, they have a section on filter gaskets/seal rings by dimension.
Or look at McMaster.com for ''square O-rings''.
https://www.mcmaster.com/4061T27/
This part number MAY fit? Price is right @ $17.83 for 25 of 'em! Might take a while to use them up tho?
Have your lazy dealer do a search through the surrounding dealers, bet somebody has some on a shelf.
Thanks for your help. The ones from McMaster Carr look right. Ill order them tomorrow. If anyone needs one youll know who to call. Thanks again
